Export Battery Profile
I have used the Otii ace to discharge a battery and generate a battery curve. I would like to export this curve and view it as a CSV. How can I do that?
Thanks
Jesse
If you right click on the recording on the left side, then you select “Export to csv”.
This will export the recording.
The battery profile with internal resistance, OCV and discharged capacity, is a json file that you can find here:
C:\Users<UserName>\AppData\Roaming\Otii 3\batteryprofiles\ (Windows)
/home//.config/Otii 3/batteryprofiles/ (Linux)
/Users//Library/Application Support/Otii 3/batteryprofiles (macOS)
