I would like to see which channels are enabled in the recording.
enabled_channels = recording.get_enabled_channels(device.id)
I try to see which channels have data using this code.
# Define all possible Otii channels manually
available_channels = [
"mc", "mp", "mv", # Main channels
"ac", "ap", "av", # ADC channels
"sp", "sn", # Sense+ / Sense-
"vb", "vj", # Voltage channels
"tp", # Temperature
"rx", # UART logs
"i1", "i2" # Digital inputs
for channel_name in available_channels:
try:
info = recording.get_channel_info(device.id, channel_name)
if not info:
print(f"Warning: No info found for channel {channel_name}. Skipping...")
continue
except Exception as e:
print(f"Error retrieving channel info for '{channel_name}': {e}")
continue
But i get broken pipe errors.
channel mc
/snapshot/client/common/lib/model/recordingRequests.js:534
const [measurementData] = recording.measurements.filter(m => m.id === measurement.id);
TypeError: Cannot read properties of undefined (reading 'id')
at /snapshot/client/common/lib/model/recordingRequests.js:534:91
at Array.filter (<anonymous>)
at RecordingRequests.getChannelInfo (/snapshot/client/common/lib/model/recordingRequests.js:534:58)
at TcpServer._TcpServer_handleRequest (/snapshot/client/common/lib/model/tcpserver.js:723:85)
at TcpServer.onData (/snapshot/client/common/lib/model/tcpserver.js:192:95)
at Object.onClientData (/snapshot/client/common/lib/model/tcpserver.js:181:22)
at Socket.<anonymous> (/snapshot/client/common/lib/model/createServer.js:19:21)
at Socket.emit (node:events:537:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
Node.js v18.5.0
the recording in device service is <otii_tcp_client.recording.Recording object at 0x7f8de33680>
Returning license and logging out...
An error occurred while returning license and logging out: [Errno 32] Broken pipe
In this example channel “ap” and “av” where enabled, but it would be nice if I don’t have to store this for every recording.
