I use ARC1.0 with Otii 3.5.3 with DC input and USB. The maximum voltage is 4.55V.
In the datasheet, it said to use the “main current : high range” to enable the 5v, but without success.
In the setting, the max supply voltage was at 4.5V.
Hi and welcome to the forum.
Great that you solved the issue yourself.
