I get an USB under-voltage detected, main power switched off error sometimes as soon as I launch the software, sometimes quite a while later after I have applied power to my device. What is this telling me about my setup?
This means that the voltage level at the USB port of your Otii Arc is low and there are some possible reasons for this.
- Your USB port on your computer doesn’t keep the power according to the USB specification. So the voltage is lower that expected.
If this is the case then try to use a powered USB hub inbetwen your computer and Otii Arc. - Your USB cable is a bad USB cable.
Are you using the USB cable supplied when you bought your Otii Arc?
This cable is build specifically for low resistance so use this if possible.
You can monitor the USB voltage by, in Otii application when you have created a project, click Device -> Meters and check the VBUS figure.
Thank you for your quick response on this topic. In response to your comments, we are using a powered USB hub. It is a Sabrent HB-U14P hub. And we are using the supplied USB cable that came with the OTII. Would an external ac adapter for the OTII prevent this issue?
Thank you for your help
Will
Sorry, but that is not a hub you want to use in this case.
Maximum output current per port is 300mA and Otii Arc will consume some of that power.
I would switch to another powered USB hub.
Connecting an external DC adapter to Otii Arc will only slightly reduce the problem.
Thanks for the info. Do you have a recommendation for a powered USB hub that would work better or that you have had good luck with?
Will.
I am using two TP-Link UH720 in my setup with 12 Otii Arcs with good results.
Check my setup in the article here:
Got the same issue. I had a Baseus 5V 3A USB A power unit suplies a Transcend USB hub https://www.transcend-info.com/product/card-reader-accessory/hub3 (which outputs 5V 2A all ports).Replaicing the power unit to 5.2V 2.4A an Apple original USB A power suplier solved the problem.
