I have different recordings with the same project settings but saved in different projects.
I should have used the same project in order to compare the recordings.
But this is where I am now and I would like to be able to import the recordings from on project into an other, in order to compare them.
Hello hugo
Unfortunately we are have no way of merging two different projects at this time. If you create a case and attach your projects there, I can try to merge them manually.
