Help Needed: Measuring Energy Consumption of BLE Device Using Otii Arc!
Hi everyone,
I am fairly new to energy profiling and recently started using the Otii Arc to measure the energy consumption of my BLE-enabled IoT sensor. I am trying to optimize battery life.., but I am a bit confused about interpreting the current spikes and idle periods in the Otii software.
This is my setup:
  • BLE sensor (custom board)
  • 3V coin cell simulation through Otii Arc
  • Logging data via Otii software on Windows
The device wakes up every 5 minutes to transmit data and then returns to sleep mode. However, the sleep current seems higher than expected (around 100µA instead of ~10µA).
I have some questions:
  • How to identify if leakage current is from the BLE module or other components?
  • Any best practices for setting up triggers in Otii for long-term logging?
  • Is it possible to use scripting in Otii to automate tests?
When I searched on the forum for the solution related to my query, I got this thread https://forum.qoitech.com/t/powering-and-measuring-embedded-device-energy-consumption-with-otii-machine-learning-course-in-bangalore
but couldn’t get enough help. Appreciate any guidance or shared experiences!
Thanks
Marcelo
Hi Marcello,
With the sub-system measurement you can check parts of the board and see if there are any unwanted current consumption:
This requires an external shunt resistor.
With Automation Toolbox license, it is possible to set up triggers and to automate tests.
There are support for python, C# and other scripting languages, I suggest that you have a look here, to get started:
Contact us if you would like to get a 14-days trial license of the Automation Toolbox.
