Iterating through data from multiple channels
I need my script to process both main current and main energy data while running a test. I need to do this every 10 seconds and get only the last 10 seconds of data from these channels to perform the processing on. I am using these calls:
        local mc_count = project:get_channel_count(box, recording_id, "mc")
        local mc_data = project:get_channel_data(box, recording_id, "mc", prev_count, mc_count)
        local me_count = project:get_channel_count(box, recording_id, "me")
        local me_data = project:get_channel_data(box, recording_id, "me", prev_count, me_count)
prev_count is the count from the last time I made these calls.
Even using prev_count, I sometimes get data that is earlier than I wanted. I also have to then match up the mc data and me data based on timestamp, which is slow when the program is running.
Is there a better way to do this? Is there a way I can get data by timestamp (rather than index)? Is there a way I can get both me and mc data without having to manually match up the samples?
Thanks!
Right now, there is no lua API for getting data by timestamp but I will add this in the back-log.
To minimise the difference you could have get_channel_count for me directly after get_channel_count for mc and then both get_channel_data.
