I have a question regarding attached image. 2 signals lost while recording and as long as I start a new record, the 2 signals went back to normal.
Thanks,
Tien
Thanks,
Tien
Hello
Could you provide information of what channels they were, i.e. Main voltage, GPI1, ADC current etc.
Hi Christer,
They were GPI1 and GPI2 signals.
Thanks,
Tien
Hi Tien,
Could you create a new case in our system and I will help you out there.
I have exactly the same problem … every time the signal break with 0 values. If I launch another record, this new one is OK for a certain time then another time goes to zero.
See here the green record falling to zero, and the red one launched just after that.
Firmware & Oti application are the latest one.
an interesting thing, when I pan/zoom the green record data seems to be all zero
and by exporting data into csv file, one can see a problem with the data themself : see a partial green curve export then after red curve.
Green data
Timestamp (S),Arc Main Current (A),Arc Main Voltage (V),Arc Main Energy (J)
0,0,2.998,0
0.00025,0,0
0.0005,0,0
0.00075,0,0
0.001,0,2.998,0
0.00125,0,0
0.0015,0,0
0.00175,0,0
0.002,0,3,0
0.00225,0,0
0.0025,0,0
0.00275,0,0
0.003,0,3,0
0.00325,0,0
0.0035,0,0
0.00375,0,0
0.004,0,3.005,0
0.00425,0,0
0.0045,0,0
0.00475,0,0
0.005,0,3.006,0
0.00525,0,0
0.0055,0,0
0.00575,0,0
0.006,0,3.003,0
0.00625,0,0
0.0065,0,0
0.00675,0,0
0.007,0,3.007,0
Red data
0,7.043e-06,3,5.28225e-09
0.00025,7.043e-06,5.28225e-09
0.0005,7.269e-06,1.0734e-08
0.00075,7.383e-06,1.627125e-08
0.001,7.444e-06,3,2.185425e-08
0.00125,7.435e-06,2.744537e-08
0.0015,7.524e-06,3.310342e-08
0.00175,7.864e-06,3.901715e-08
0.002,7.727e-06,3.008,4.482785e-08
0.00225,7.524e-06,5.047837e-08
0.0025,7.284e-06,5.594866e-08
0.00275,7.095e-06,6.1277e-08
0.003,7.095e-06,3.004,6.660535e-08
0.00325,7.69e-06,7.238438e-08
0.0035,7.699e-06,7.817018e-08
0.00375,8.204e-06,8.433549e-08
0.004,8.039e-06,3.006,9.03768e-08
0.00425,7.505e-06,9.600367e-08
0.0045,7.354e-06,1.015173e-07
0.00475,7.255e-06,1.069568e-07
0.005,7.194e-06,2.999,1.123505e-07
0.00525,6.93e-06,1.175514e-07
0.0055,6.991e-06,1.227982e-07
0.00575,7.241e-06,1.282325e-07
0.006,7.421e-06,3.002,1.33802e-07
0.00625,8.45e-06,1.401395e-07
0.0065,1.0007e-05,1.476448e-07
System Info is
Hi fchaxel, welcome to the forum!
This seems strange and we have not seen this before.
Could you create a case in our case system with a more detailed description how your setup looks like and also add the otii project file there.
When the analysis is done, I will post the outcome here in this forum.
I promised a note regarding this issue.
The strange behavior disappeared when folder for temporary project files was changed to a local folder.
This is done in File -> Preferences -> Open project folder
