Is there any way to run the battery profiler at 20 uA for the low discharge current? The minimum in the UI is 100 uA.
Thank you
Regarding the lowest possible discharge current, there is a difference between Otii Arc and Otii Ace.
Otii Arc has the lower limit of 100uA and Otii Ace has the lower limit of 1uA.
You can find the specification differences here:
