Exciting product you have here. Seems perfect for my needs.
Here and there (eg in the “what’s included”, in forums, sw downloads) I see the Nordic PPK is mentioned. Can you clarify what this means? If I understand correctly, before the Arc, you supported using the PPK?
Yes, we supported the PPK before our Arc was released. We have since then also added support for the latest PPK firmware 1.1.0.
You can connect and make recordings with the PPK if you have a standard or premium SW license. More information about how you can use the PPK can be found in the documentation in the application help menu.
