But it doesn’t work. I have the following error : “Error message: Save failed, no file name specified”. I tried others ways to write the command but this is always the same message.
Can you help me please ?
Thanks
But I had the right filename because now I have this error :
“SyntaxError: (unicode error) ‘unicodeescape’ codec can’t decode bytes in position 2-3: truncated \UXXXXXXXX escape”
I’ve always same error : “Error message: Save failed, no file name specified”
I tried all combinations for the path. Can you please send me one working script ?
Maybe something is wrong on mine. I may have forgot something
Thank you !
BR,
Solene
#!/usr/bin/env python
import time
import sys, os
sys.path.append(os.path.normpath(os.path.join(os.path.dirname(__file__), '..')))
from otii_tcp_client import otii_connection, otii_exception, otii
HOST = {
# IP address of the server
"IP":"127.0.0.1",
# Port number the server is listening on
"PORT":1905
def setup_device(my_device, voltage=3.0, overcurrent=1.0, channels=["mc"]):
my_device.set_main_voltage(voltage)
my_device.set_max_current(overcurrent) # Set overcurrent limit
for channel in channels:
my_device.enable_channel(channel, True) # Enable channels, default main current
# Check if there is already an active project otherwise create a new
def check_create_project(otii_object):
proj = otii_object.get_active_project()
if proj:
print("Project already active, close active project to continue")
sys.exit()
else:
proj = otii_object.create_project()
print("Project created")
return proj
def measure(proj, my_device, duration=1):
my_device.set_main(True) # close output relay
proj.start_recording() # start a recording
time.sleep(duration)
proj.stop_recording()
my_device.set_main(False) # close output relay
recording = proj.get_last_recording() # Get the data from the recording
return recording
def save_project(proj, filename):
proj.save_as(filename)
# Connect to Otii Arc, make sure that you have TCP server running
connection = otii_connection.OtiiConnection(HOST["IP"], HOST["PORT"])
connect_response = connection.connect_to_server()
if connect_response["type"] == "error":
print("Exit! Error code: " + connect_response["errorcode"] + ", Description: " + connect_response["data"]["message"])
sys.exit()
try:
otii_object = otii.Otii(connection)
devices = otii_object.get_devices()
if len(devices) == 0:
print("No device connected!")
sys.exit()
my_device = devices[0] # All connected devices are in the list devices, uses the first
setup_device(my_device) # Setup the device to be used
proj = check_create_project(otii_object) # Create the measurement project
my_recording = measure(proj, my_device, 10)
filename = "C://Bjorn//test_of_save.otii"
except otii_exception.Otii_Exception as e:
print("Error message: " + e.message)
print("Done!")
This works now, thanks !
My error was to write “proj.save(filename)” and not “proj.save_as(filename)”
I don’t find this precision anywhere but I’m new on Python so maybe this was obvious for others
