Run script on command-line
Hi, I am new on OTII Automation toolbox
I need to launch a python script without open manually OTII soft. For this :
I open command-line and type : otiicli -s example_basic_function_check.py’
And after that, I cannot write anything without quitting the server listening. So I can’t launch my script. This is the same reaction for ‘otiicli -s’
I also tried ‘otiicli example_basic_function_check.py’ but it doesn’t work without start server listening before.
Do you have some advice to help me ?
Thanks !
Hi, problem solved
I didn’t see the following link : Qoitech Documentation, it was very helpful. Thanks.
Just a comment in " Start otiicli from Script" chapter :
I imported subprocess : import subprocess
I pasted the following script part and changed my USERNAME and PASSWORD by mine:
cmd = f'otiicli --server --username={USERNAME} --password={PASSWORD}'
server = subprocess.Popen(cmd, shell=True)
Then, I used those lines :
connection = otii_connection.OtiiConnection(cfg.HOST["IP"], cfg.HOST["PORT"])
connect_response = connection.connect_to_server()
if connect_response["type"] == "error":
    print("Exit! Error code: " + connect_response["errorcode"] + ", Description: " + connect_response["data"]["message"])
    sys.exit()
It permits to make no change on Host IP and Port comparing to the given script.
Maybe this will help someone !
I forgot :
for the second lines, we must add : import example_config as cfg
the example_config.py script :
#!/usr/bin/env python
HOST = {
    # IP address of the server
    "IP":"127.0.0.1",
    # Port number the server is listening on
    "PORT":1905
Thank you for posting this!
