Because I had some issues to connect to server, I received from Qoitech an USB dongle to activate my license.
This is perfectly working, the license appears when I open otii.exe.
But some errors appears now when I launch automation tests because the example scripts are made for a connection to server:
#Launch OTII and connect to server
cmd = f'otiicli --server --username={cfg.HOST["USERNAME"]} --password={cfg.HOST["PASSWORD"]}'
server = subprocess.Popen(cmd, shell=True)
connection = otii_connection.OtiiConnection(cfg.HOST["IP"], cfg.HOST["PORT"])
connect_response = connection.connect_to_server()
if connect_response["type"] == "error":
print("Exit! Error code: " + connect_response["errorcode"] + ", Description: " + connect_response["data"]["message"])
sys.exit()
[Extract from an example script found on github]
When I delete the connection commands, I cannot launch my tests because following instructions need this information.
Do you have some example scripts when we use an USB dongle please? Or a list of commands to remove/add ?
Solene
