This is what my project setting page looks like (all the way up to UART-21 since I have 1 16 way FTDI UART/USB adaptor plugged in.) Would it make more sense to either place “ARC” in its own row or prioritise it so that it appears first in the list?
Thank you for this suggestion, it is appreciated.
Remember that you can hide the ones you do not want to see by right clicking and choose ignore.
They will then be added in the uart_blacklist.json located in \Documents\otii folder.
Thanks Bjorn, the context menu I get on right-click is actually “Hide Product Type” When I do this, Most of the uarts disappear (perhaps it’s filtering on the driver type?).
The key point though is that the ARC icon is not displayed (even if I scroll left or right) meaning that I’m unable to edit the supply voltage.
Edit - the missing ARC icon was solved by unplugging and reconnecting the OTII usb cable - a bit odd since it was able to generate recordings while in this mode…
In the next software release, Arcs will be prioritized in this list.
Thank you for the feedback and for your suggestion!
Super - thanks!
