I wish to be able to control Otii with another application, not just scripting through Lua inside Otii.
I see there is a event_loop.lua example which creates a local server (?) - but I can’t see how I can send commands to this server from another application.
Yes, you can use this to open a named socket which an other application can connect to and send commands that your Lua script will act upon. I’ll use the event_loop.lua script as example here.
On linux you can send things to it by using netcat for example.
nc -U /tmp/com.qoitech.otiicli
Then you can write commands, for example ‘on’ and ‘start’. Please note that you need to terminate the command with an EOF signal and not a newline. On linux you can produce a EOF by pressing CTRL+D.
In python you use the socket module.
import socket
s = socket.socket(socket.AF_UNIX, socket.SOCK_STREAM)
s.connect(“/tmp/com.qoitech.otiicli”)
s.send(‘start’.encode(‘utf-8’))
This will send ‘start’ to the Lua script.
I know this is possible to do on Windows as well. On a recent windows 10 you should have AF_UNIX support according to this article by Microsoft.
Before that it might be named pipes that are used. You can read more about that here. I’ll try to get a confirmation from someone in the team that knows windows better than me on Monday.
Hope this helps, and don’t hesitate to ask additional questions.
In MacOs the named unix domain socket is a bit tricky to find, but e.g. with Python, the psutils is quite handy for this, providing platform independent solution. Example:
import psutil
servername=“com.qoitech.otiicli”
path = [sock.laddr for sock in psutil.net_connections(‘unix’) if servername in sock.laddr][0]
s.connect(path)
sockets in MacOs can be found with netstat as in Linux but they seem to locate like following example:
