I connected my Arduino MKR GSM 1400 to the OTII arc using external power supply (7.5V from an adapter) through the 7-9V port, and connected it to the computer using USB port to supply 3.7V.
It took some work to minimize the power consumption. I’ll dig up the old code and doublecheck it first, and if power consumption looks OK I’ll share the setup with you.
Will try to come back on this tomorrow Thursday.
/Marc
Hi, seems original code disappeared with my previous laptop, but I had some junk code laying around and could re-create it. I attach the measurements here, about 3.07 mA in sleep mode. The trick seems to be to put the SAMD21 to sleep properly. If you open a case in our case system I’ll give you the (very ugly) code as well.MKR1400 - 3mA.otii (1.2 MB)
It would be a huge help if you could kindly share the rough code.
We are running a bit stretched on deadlines so would really appreciate if you could share it at your
earliest convenience.
Is there a procedure to open a case?
Hi there! I’m following up on this, as I am working on a similar project, and am having readings consistent with kbhargava with my MKR GSM 1400. I would appreciate the code for putting the SAMD unit to sleep.
Hi Bjorn! I’ve submitted a case a few days ago now, but am not quite sure what you mean by referring the case to MKR GSM 1400? Would love to get some input!
