When I want to update the device to version 3 with right mouse button:
Nothing happens.
Have you had this problem before?
Nothing happens.
This might be that you are behind a proxy/firewall.
We are working on a solution for this.
In the meantime, you can try to update outside the proxy or download the firmware from the download page in user management on our web page. Then select your Arc and in the menu update firmware from file.
thanks for the answer but this is not possible
just for your information I surrounded now the proxy. thanks for the hint. Maybe an error message would be fine.
Yes, fault handling will also be improved a lot.
