With Otii 2.4.0 installed from the deb, I get a warning that it has unmet dependencies when running apt again, meaning that it’s not possible to install other software without uninstalling Otii first.
Although the Otii software appears to function (I don’t have a premium package to check extended functionality), it did fail to install silently when using the Software Center to install the deb, and only actually installed by using dpkg on the command line.
OS: Ubuntu 18.04
Otii version: 2.4.0
Steps to reproduce: Install with sudo dpkg -i otii_2.4.0.deb
Expected result: dpkg should be able to meet all the dependencies of otii during install
Actual result: otii installs an appear to work with all the expected features (no licence key used), but the unmet dependencies mean otii has to be removed before any other software can be installed or updated.
Following install of Otii:
~ % sudo apt install <any_package>
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies.
otii : Depends: libssl-dev (< 1.1.0) but it is not going to be installed or
libssl1.0-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Following apt’s suggestion to --fix-broken:
~ % sudo apt -f install
Correcting dependencies... Done
The following packages will be REMOVED
otii
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 112 MB disk space will be freed.
Do you want to continue? [Y/n]
The current version of libssl-dev is 1.1.0g-2ubuntu4.3, there is a version <1.1.0 in libssl1.0-dev 1.0.2n-1ubuntu5.
What’s the best way to go about solving this problem?
